Can FCPro 5 Handle DVCPRO HD ?
Max Jackson
on Jun 30, 2011 at 10:26:03 am
Hi CC,
I've got a project that requires 15 fps and FCPro 5 is the only thing that might work for the project.
Before erasing my entire computer I was hoping to know if FCPro 5 can handle DVCPRO HD (1080i60), Linear PCM, Timecode fomrat.
Is that so?
Thanks a bunch for any feedback. :)
Rafael Amador
Re: Can FCPro 5 Handle DVCPRO HD ?
on Jun 30, 2011 at 10:37:15 am
[Max Jackson] "Before erasing my entire computer I was hoping to know if FCPro 5 can handle DVCPRO HD (1080i60), Linear PCM, Timecode fomrat."
Yes.
No problem.
[Max Jackson] "I've got a project that requires 15 fps and FCPro 5 is the only thing that might work for the project."
is your footage 15fps?
rafael
http://www.nagavideo.com
Jeremy Garchow
on Jun 30, 2011 at 10:53:00 am
Dvcpro HD is fine. 15fps won't work.
What are you trying to do?
Chris Tompkins
on Jun 30, 2011 at 3:58:17 pm
Edit full res/frame size/rate.
Export "Current settings"
THEN,
Compress for delivery.
Chris Tompkins
Video Atlanta LLC
Max Jackson
on Jun 30, 2011 at 8:25:14 pm
Hi everybody,
My footage was shot at 30 fps, but with double frames. I'm not sure what the technical term is, but it's like 1/1, 2/2, 3/3, etc. because my final cut is going to be in 15 fps, almost like a flipbook.
I can't edit in 30 fps and then change speeds for audio matching-sake.
However, I've managed to get Premiere to interpret the footage though, so I'm most likely going to go with that instead just because my project is so left field.
Thanks a bunch for all your feedback! :)
