FCP Export breaks into multiple files
Rachael Priddel
on Jun 30, 2011 at 3:00:13 am
I'm having issues when exporting from my final cut timeline.
When exporting pro-res footage from either a pro-res or XDCAM timeline the final export breaks multiple files. I end up with:
EXAMPLE.mov
EXAMPLE-av1.mov
EXAMPLE-av2.mov
etc.
Each of these files 2.05GB (except for the last).
I can play the whole clip through Quicktime by playing the EXAMPLE.mov file, though it won't play if I delete the others.
It does work through quicktime compression, although that takes twice as long to export.
Any help would be greatly appreciated,
Thank you
Jeremy Garchow
Re: FCP Export breaks into multiple files
on Jun 30, 2011 at 3:46:30 am
The hard drive you are exporting to is not formatted as Hfs+ (Mac OS Extended). You can check in disk utility.
David Roth Weiss
on Jun 30, 2011 at 5:02:06 am
Yep, Jeremy is advising you correctly - your drive is currently formatted FAT32 (for PC), which has either a 2 or sometimes 4Gb file size limitation.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
http://www.drwfilms.com
Don't miss my new tutorial: Prepare for a seamless transition to FCP X and OS X Lion
http://library.creativecow.net/weiss_roth_david/FCP-10-MAC-Lion/1
Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
Rachael Priddel
on Jul 1, 2011 at 4:19:09 am
Thanks for your help, though the Hardrive I am using is Mac OS Extended and I have written to it before without this problem. Could there be another reason for this?
James Lovell
on Jul 20, 2011 at 3:14:52 pm
I have just had the same problem. I am using the same harddrive, fcp file and media but suddenly after a restart due to the finder crashing it splits the mov files into 2 gig sections. Most annoying!
