MTS Files
Sascha Engel
MTS Files
on Jun 29, 2011 at 4:44:32 pm
I tried to find former posts on this one, but could not get a clear answer.
If I have MTS files and I wanna make them FCP 6 ready, can I convert them in Toast in a good quality?
I know, it works, but does Toast do a good job?
Sascha
Chris Borjis
Re: MTS Files
on Jun 29, 2011 at 5:05:18 pm
no.
use compressor.
Sascha Engel
Re: MTS Files
on Jun 29, 2011 at 6:58:51 pm
Hi Chris,
I don't know which compressor you are talking about, but if it's the one from FCS, it does not accept MTS files.
Any other idea?
Sascha
Chris Borjis
Re: MTS Files
on Jun 29, 2011 at 9:08:53 pm
oh dear...oops I remember that now.
clipwrap will do it. I find it an essential tool at a very low cost.
Sascha Engel
Re: MTS Files
on Jun 30, 2011 at 3:03:58 pm
Hi Chris,
tried it. Actually Toast is better, even does a preety good de-interlaceing!
Sascha
Andrew Evans
Re: MTS Files
on Jun 30, 2011 at 3:57:39 pm
I use adobe media encoder. Does the best job I've ever seen.
Sascha Engel
Re: MTS Files
on Jun 30, 2011 at 4:24:20 pm
Tried that one right now...very good result.
Still: Toast is equally good. I am surprised myself, but it does hell of a Job!
Sascha
Chris Borjis
Re: MTS Files
on Jun 30, 2011 at 4:53:37 pm
MTS>ProRes with Toast?? and it looks good?
I never would have thought that possible.
interesting.
Sascha Engel
Re: MTS Files
on Jun 30, 2011 at 4:58:54 pm
Me neither...and even more: I also converted the frame rate 29.97 to 25.
I did all the same with Clipwarp & Media Encoder - and Toast pretty much stood up to it.
Things you definitely would not expect!
Respect to Toast!
Sascha
Isaac Brillant
Re: MTS Files
on Sep 4, 2011 at 7:24:57 pm
Do you know if - using Toast or one of the other converter programs - you can import the MTS files you want to use and create a new folder structure that FCP could recognize?
I'd like to be able to just save my MTS files rather than backing up each SD card, and then if I want to bring them into FCP, create a new folder structure that L&T could read.
This way I could view them in FCP, in the L&T window, before having to transcode them all.
Also, which Toast are you using? I only have Toast 9...
