FCP won't start
Chris Brown
FCP won't start
on Jun 28, 2011 at 8:23:54 am
I've been having problems installing final cut studio 2 after installing final cut studio 3, were the final cut option way greyed out and stated it would be skipped your install. I got around this by using the FCS romver. So i can now install fcp but when i go to launch the app i get the following error:
Process: Final Cut Pro [198]
Path: /Applications/Final Cut Cut Pro
Version: ??? (???)
Build Info: FCPApp-706230001~3
Code Type: X86 (Native)
Parent Process: launchd [112]
Date/Time: 2011-06-28 09:17:40.927 +0100
OS Version: Mac OS X 10.6.8 (10K540)
Report Version: 6
Interval Since Last Report: 126016 sec
Crashes Since Last Report: 507
Per-App Crashes Since Last Report: 2
Anonymous UUID: D078FA7D-43BA-4DF3-876A-E188124EBC6E
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread: 0
Dyld Error Message:
Library not loaded: /Library/Frameworks/ProFX.framework/Versions/A/ProFX
Referenced from: /Applications/Final Cut Cut Pro
Reason: image not found
Binary Images:
0x8fe00000 - 0x8fe4162b dyld 132.1 (???) <283EE026-C0FE-1FF9-DB81-BFB155793157> /usr/lib/dyld
Model: iMac12,1, BootROM IM121.0047.B0A, 4 processors, Intel Core i5, 2.7 GHz, 4 GB, SMC 1.71f21
Graphics: AMD Radeon HD 6770M, AMD Radeon HD 6770M, PCIe, 512 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x9A), Atheros 9380:
Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: WDC WD1001FALS-403AA0, 931.51 GB
Serial ATA Device: HL-DT-STDVDRW GA32N, 4.36 GB
USB Device: FaceTime HD Camera (Built-in), 0x05ac (Apple Inc.), 0x850b, 0xfa200000 / 3
USB Device: Hub, 0x0424 (SMSC), 0x2514, 0xfa100000 / 2
USB Device: USB-PS/2 Optical Mouse, 0x046d (Logitech Inc.), 0xc01d, 0xfa130000 / 5
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0xfa110000 / 4
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8215, 0xfa111000 / 6
USB Device: Hub, 0x0424 (SMSC), 0x2514, 0xfd100000 / 2
USB Device: Internal Memory Card Reader, 0x05ac (Apple Inc.), 0x8403, 0xfd110000 / 4
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0xfd120000 / 3
FireWire Device: unknown_device, Unknown
Any help would be great
Tony Silanskas
Re: FCP won't start
on Jun 28, 2011 at 9:23:01 pm
This might not help you, but did you backup your system before you updated? Can you copy that backup back to your main drive and try again?
© 2018 All Rights Reserved
