Conforming sequence to clip issue
david reichelt
on Jun 28, 2011 at 7:07:32 am
I'm having slight problem and am not sure what I am missing. I want to be able to drag a clip into my sequence and have the sequence conform to the clip settings so no rendering is needed. I went to user prefs>editing tab and made sure to have it ask me whether or not to do this when a clip is brought in. However, no pop up comes up and the clip shows that it needs rendering. Can someone please tell me what I'm missing? I have FCP 6 by the way. Thank you.
adam taylor
Re: Conforming sequence to clip issue
on Jun 28, 2011 at 9:08:39 am
what format is the file you want to use?
Its possible the file is one that cannot be used in realtime and will need rendering regardless of the timeline setting.
Adam Taylor
Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
Character Options Ltd
Oldham, UK
http://www.sculptedbliss.co.uk
My YouTube Animations Page
Alexander Kallas
on Jun 28, 2011 at 12:55:27 pm
With the first clip you pull into the time-line, FCP will offer to match the sequence settings. This will lock that sequence to those settings. Any subsequent addition that does not have the same specs will cause the render bar to appear.
Cheers
Alexander
Chris Tompkins
on Jun 28, 2011 at 3:19:36 pm
Not true. Deleter ALL clips from the sequence and THEN drag a clip in and u'll get the mess. again.
Chris Tompkins
Video Atlanta LLC
