FCP on Unity Crasing frequently.
Dan Marlow
on Jun 23, 2011 at 2:10:43 pm
HI,
Having trouble running Final Cut Pro (7.0.3) on a Westmere (10.6.4 os) on a unity via a Fibre connection. The Kernel is switched to 32 Bit to allow the unity to run. Client Unity software version is 5.3.2. The unity server itself is running on 5.1.4. The suite also runs a Blackmagic Eclipse.
Basically, every 30 mins or so the FCP goes to spinning wheel, and doesn't return to normal. Opening force quit shows that neither FCP nor Fibre Manager are responding.
Can anyone see any problem with this setup?
Had a search on here and found some similar isssues, but not a solution that worked for me. Any help would be greatly appreciated...
Cheers
Dan Marlow
Re: FCP on Unity Crasing frequently.
on Jun 25, 2011 at 10:37:49 am
Just discovered that it would seem the slot config is hardwired on the Westmere Mac Pros. Hoping correcting the pci slot order helps.
Dan Marlow
on Jun 26, 2011 at 7:59:28 am
spoke too soon. hasn't fixed it
Dan Marlow
on Jul 17, 2011 at 9:36:09 am
Completely deleted and reinstalled the FCP Startup HD. Still crashing.
Dan Marlow
on Jul 18, 2011 at 8:49:47 am
Ok. Should anyone have the same problem - rolled the Avid Unity Fibre Manager back to v5.2 and seems to be fixed.
