Best setting for titles?
chris long
on Jun 21, 2011 at 10:07:45 pm
Hi there,
I've just completed a music video and need to add lower third titles. When I rendered them and watched them back, they looked awful - very 'blocky'. Can anyone suggest a good workflow and format for titles? Should I create them in Motion 4 and export as animation, then import into FCP?
Chris
Chris Borjis
Re: Best setting for titles?
on Jun 21, 2011 at 10:15:45 pm
Chris are you using the included Boris 3d Titler?
Chris Tompkins
on Jun 21, 2011 at 10:48:08 pm
Your sequence settings?
Chris Tompkins
Video Atlanta LLC
chris long
on Jun 21, 2011 at 11:11:19 pm
No, I'm just using the regular text tool from the drop down. Your question as to the sequence settings is a good one - I'm using someone else's Macbook Pro and I need to check the settings since I took over the edit - thanks for reminding me!
Chris Borjis
on Jun 24, 2011 at 4:47:14 pm
use the boris 3d titler....the apple one is awful.
