Render Problems (PSD file)
Rory Keenan
on Jun 21, 2011 at 1:15:15 am
My Graphics look good until I render them.
Is there something I'm missing?
I Imported a Photoshop file with an alpha channel.
I need to lay this on a brown background.
I have 2 layers of video:
Layer 1- The logo (psd file)
Layer 2- A color matte created in FCP
The graphic look fine when I assemble it in a sequence
However when I render it there is a weird pixelated halo around the graphic.
It look terrible
Any Solutions?
Michael Gissing
Re: Render Problems (PSD file)
on Jun 21, 2011 at 5:48:43 am
My guess (with such little important info supplied) is you are using a sequence codec that is highly compressed like DV.
If so then choose a sequence codec that is kind on graphics like Uncompressed 10 bit or ProRes422. Change your easy setup, make a new sequence and copy paste your sequence into the new timeline. Re-render with render set to best
James Vincent
on Jun 21, 2011 at 8:02:25 pm
do a test export (apple-E) and see if the psd still looks bad, it could be that your psd needs a full render (no grayish-green or green bar)
© 2018 All Rights Reserved
