Apple Compressor Destination Headache
Rick Symonds
on Jun 20, 2011 at 4:58:41 pm
No matter what I do I can't seem to get the destination droplet to work. Every time I add a clip to compressor, select a setting and then try to add a destination I get 'Each target assigned to a job must have a setting and destination.' when I hit submit.
I've tried both custom destinations as well as the apple ones. I'm u sing just a single clip and dragging the droplets down. What I want to be able to do is directly upload a clip to my FTP via compressor but I can't seem to get anything to work when assigning a destination.
Rick
Jerry Hofmann
Re: Apple Compressor Destination Headache
on Jun 20, 2011 at 5:18:23 pm
The only places you can send the file to is a drive, Mobile me account, YouTube... don't think there's a way from within Compressor to make the destination a web address.
But Compressor has the option to execute an AppleScript if you know how to use that for the upload there might be a way to do it that way?
But you could do it easily from within Sorenson's Squeeze or Telestream's software... better compression software either one to boot.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
