green screen dv pal and pro res
tas underwood
on Jun 15, 2011 at 4:33:12 pm
Hi there,
I have some footage that I have captured on a Z7 (M2T files). I have then encoded them to apple pro res using Mpeg Streamclip and then keying it in final cut. This seems to be a slow process and was wondering what the best process is. Can i put the prores files into After Effects and export. The final file format doesnt have to be HD.
Anyones help on this would be massively appreciated!!!
Dave LaRonde
Re: green screen dv pal and pro res
on Jun 15, 2011 at 6:56:21 pm
You're not entirely clear on what's slowing you down. Can you specify?
Dave LaRonde
Sr. Promotion Producer
tas underwood
on Jun 15, 2011 at 7:01:25 pm
The rendering in final cut is slow and converting to pro res from mpeg streamclip. Is this the right process to follow?
Dave LaRonde
on Jun 15, 2011 at 7:43:27 pm
Yes, that's the way to do it. It takes a certain amount of time to convert those mts files. Since FCP can't chroma key in real time, it has to render.
Dave LaRonde
Brendan Maghran
on Jun 15, 2011 at 7:44:14 pm
Sounds like you're doing fine, compositing isn't exactly the fastest of all processes. Are you asking about keying in AE?
tas underwood
on Jun 15, 2011 at 7:51:27 pm
Yeah was wondering whether it was better to import pro res files into ae then use keylight and export. But is animation codec only one that will work with transparency?
Dave LaRonde
on Jun 15, 2011 at 8:27:03 pm
Quicktime's PNG codec will also support alpha channels.
If you run AE on the same machine as FCP (ver. 7 only), you can also use ProRes 4444, which may even play in real time.
But if you're going to go to all that trouble, why not just do the entire shot -- foreground AND background -- in AE? Sure, you have to pick the background beforehand, but that's not tough.
There are two bonuses to doing this:
  • You see the keyed subject over the background, so you KNOW the key is right, and you can color correct so the subject looks like it belongs with the background.
  • You can render out the entire shot in ProRes 422, no alpha channel necessary.
Dave LaRonde
