Create flv in FCP 7
Scott Dressel-Martin
Create flv in FCP 7
on Jun 15, 2011 at 1:40:00 pm
I have read some of the older threads on flv from fcp 7 and am wondering if there is any newer solutions for creating an flv file in fcp 7? I have a client that must have an flv file and I'd like to give them a quality file. Thanks!!
Shane Ross
Re: Create flv in FCP 7
on Jun 15, 2011 at 3:19:28 pm
You need third party solutions like Sorenson Squeeze.
Shane
matthew bradshaw
on Jun 15, 2011 at 3:34:21 pm
It has been a while but can't you just export an mpeg4 (h.264) and change the suffix to flv?
Matt.
Bret Williams
on Jun 15, 2011 at 4:44:35 pm
Yes. Works perfectly for flv. And usually fine for f4v as well.
on Jun 15, 2011 at 6:16:33 pm
Thanks for the input. I did try changing the suffix to .flv and for some reason it didn't work for the client. I have tried using Adobe Media Encoder CS5 and it seems to have worked. We'll see what what the client says.
Thanks everyone for the help. I think I'm okay now.
Cheers!
