mac the ripper
Diane Mason
mac the ripper
on Jun 13, 2011 at 7:50:35 pm
What is a step-by-step how-to for taking clips from a DVD using Mac the Ripper?
Thank you!
Shane Ross
Re: mac the ripper
on Jun 13, 2011 at 8:49:26 pm
For use in FCP... There are none. That doesn't make files that FCP uses. You need MPEG Streamclip.
Shane
Diane Mason
Re: mac the ripper
on Jun 13, 2011 at 8:56:02 pm
Thank you, Shane! I do have Streamclip so will use that. It is helpful to know the MtR doesn't work with FCP.
I will check out your bog.
Thanks again for taking the time to respond.
Shane Ross
Re: mac the ripper
on Jun 13, 2011 at 9:09:00 pm
Here's the first post to check out...how to use MPEG STREAMCLIP for getting footage to FCP>
http://lfhd.net/2009/06/26/mpeg-streamclip-tutorial/
Shane
Diane Mason
Re: mac the ripper
on Jun 13, 2011 at 9:16:42 pm
Thank you! That's a great tutorial. I will use it!
