Stuttering Timeline Playback
Mike Petty
on Jun 13, 2011 at 2:05:09 pm
Playback in my timeline is all of the sudden stuttering/jittery. Especially noticeable on dolly shots or pans. I am working in ProRes LT. I have trashed prefs...restarted...no joy - the problem persists. When I output to a QT movie the footage is fine...no stutter.
For the record this is canon 7D footage transferred in the Canon Plug in. That may be the issue. I have MB Grinder but I never use it. I am working on a big Mac Pro with lots or memory.
Very annoying. Any ideas, kids?
MP
Dave LaRonde
Re: Stuttering Timeline Playback
on Jun 13, 2011 at 4:18:40 pm
Frame rate mismatch between footage & timeline?
Dave LaRonde
Sr. Promotion Producer
Mike Petty
on Jun 13, 2011 at 5:10:52 pm
I just dropped the clips into the timeline, got the query to match the footage and proceeded so that should not be a problem, right. Could it be an RT problem?
Dave LaRonde
on Jun 13, 2011 at 5:27:38 pm
Sure could be. It's easy to check by messing around with the RT settings in the upper left of the timeline.
Dave LaRonde
Chris Tompkins
on Jun 13, 2011 at 7:04:13 pm
You didn't mention the Hard drive you are playing the media off of...
Chris Tompkins
Video Atlanta LLC
Mike Petty
on Jun 13, 2011 at 8:57:27 pm
The hard drive is an internal project drive with a ton of space. I think I may have found the problem. I believe the timeline may have been out of whack with the clip speed. Can't remember what I had it at before but when I dumped the prefs I reset the timeline at XDCAM EX/30fps (for my main work camera.
The clips in question are 23.98 PRo Res LT.
I just checked the sequence video settings & Easy Setup and reset them for Pro Res 422...
Smoothed out.
It's alway something. When is FCP X coming???
Dave LaRonde
on Jun 13, 2011 at 9:22:13 pm
[Mike Petty] "When is FCP X coming???"
There's a whole forum on the COW devoted to that very question:
http://forums.creativecow.net/finalcutprox
Dave LaRonde
