Rendered Clips Will Not Save
Rudy Moni
on Jun 10, 2011 at 10:30:56 pm
When I render clips in the timeline ( like a greenscreen composite clip ) and save it to the browser . . . when I bring the clip back into the timieline later it needs to be rendered again. Is there a way to save the rendered clip so that I do not have to render it again? Thank you
Jerry Hofmann
Re: Rendered Clips Will Not Save
on Jun 10, 2011 at 10:44:14 pm
Render files can only be saved in sequences. so you might save a small sequence instead?
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Rudy Moni
on Jun 15, 2011 at 9:12:27 pm
Hello Jerry,
I appreciate the response. I did that by "accident" once. It seems like the way to go.
Thank you,
Rudy
