Sean Davison
on Jun 9, 2011 at 9:19:15 pm
I need to get an XDCam sourced Avid Project into FCP for A color Grade
I have Automatic Duck but it didn't used to work with Non Tape based rushes
Has this changed or can anyone point to any other conversion software?
Life on the Bleedin' Cutting Edge....
Shane Ross
Re: Avid/FCP
on Jun 9, 2011 at 9:24:23 pm
What version do you have? Update to the latest version if you can. It does work with tapeless just fine. I use it constantly for going back and forth. That I do more often that I thought I would.
There is Boris AAF transfer...but it isn't as good as the Duck. Update the duck and you should be good to go.
Ben Scott
Re: Avid/FCP
on Jun 10, 2011 at 9:00:33 am
automatic duck may work well with tapeless
only issue I would say is watch out with reconforming xdcam ex and probably the other xdcam, not as well implemented as other tapeless format for reconforming in my experience
i have tried AAF with embedded media and then imported with automatic duck, then transcoding the dnx media quicktimes it creates to something like prores, works well on short pieces.
© 2018 All Rights Reserved
