How to setup and monitor IRE settings in Final Cut Pro
John Martin
on Jun 9, 2011 at 6:59:56 pm
How do I view my IRE settings in final cut pro? Will broadcast safe setting ensure I'm within the range? I'm trying to output my video to the IRE standard of 7.5 IRE and have the Luminance below 100 IRE, and to have the Chroma levels not exceed 120 IRE. Below are the exact specs.
-Setup level should equal 7.5 IRE
- Luminance levels should not exceed 100 IRE
- Chroma levels should not exceed 120 IRE
Thanks for the help!
Shane Ross
Re: How to setup and monitor IRE settings in Final Cut Pro
on Jun 9, 2011 at 7:28:52 pm
Under the TOOLS menu...there are VIDEO SCOPES. That's where you look.
[John Martin] "Will broadcast safe setting ensure I'm within the range?"
Not always. It can be the last little bit you use to ensure you are good, but really, you should use the 3-way color corrector and Proc Amp to get you to where you need to be.
Shane
David Roth Weiss
on Jun 9, 2011 at 8:54:47 pm
[John Martin] "I'm trying to output my video to the IRE standard of 7.5 IRE"
Maybe 7.5 maybe not... What type of video are you editing?
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
http://www.drwfilms.com
Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
John Martin
on Jun 9, 2011 at 9:50:35 pm
It's a com. spot for a client out here. A specific delivery spec, it calls for "IRE" standards. I've mostly dealt with broadcast safe mode, not the scopes in FCP, or measuring IRE.
DO you know of a feature (or third party software) to help monitor IRE standards?
J
Shane Ross
on Jun 9, 2011 at 10:00:52 pm
[John Martin] "DO you know of a feature (or third party software) to help monitor IRE standards?
Yes. As I said, the built in VIDEO SCOPES, in the TOOLS menu. They show you the indicators for all the IRE levels, including 100 and 7.5. Don't know how to read them? Want to make sure this passes broadcast QC? Hire an online editor. Either have them do it, or show you how to do it.
Shane
Steve Eisen
on Jun 9, 2011 at 10:03:18 pm
http://www.dcainc.com/products/eos/
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
John Martin
on Jun 13, 2011 at 8:00:25 pm
Thanks! Very helpful, this is just the plugin I was looking for.
David Roth Weiss
on Jun 9, 2011 at 10:16:15 pm
[John Martin] "A specific delivery spec, it calls for "IRE" standards."
You never answered my question. What codec are you editing? I ask, because 7.5 IRE is essentially the standard for legacy analog video, while the standard for digital video is "0" IRE.
Did the delivery specs call for 7.5 IRE specifically?
David Roth Weiss
Los Angeles
Rafael Amador
on Jun 9, 2011 at 10:28:15 pm
Forget about the 7.5 IRE in FC.
Those values are for the "analog world".
The 7.5 IRE must be added by a video card when putting out analog.
You don't have to add that to your FC image. Files exported with those 7.5 IRE will be wrong.
In FC you keep your Blacks at 0 and Luma at 100%.
[John Martin] "- Chroma levels should not exceed 120 IRE"
That's is not really "Chroma" but the Composite signal, which can not pass 120 IRE.
You can not properly monitor the Composite signal in FC. The top value you can read is 110 IRE.
You need an external scope to set this properly, however you can easily set the FC's "Broadcast Safe" filter for those values.
rafael
http://www.nagavideo.com
Mark Johnnidis
on Sep 6, 2011 at 6:57:06 pm
I also have been requested to deliver in the IRE 7.5 format but I am delivering a ProRes file uploaded to an FTP. Should I set my blacks to 7.5 or 0???
I believe they will be laying off to DigiBeta and HDCam after I deliver it to them. What is the proper protocol on this?
Chris Wiggles
on Sep 6, 2011 at 9:39:36 pm
IRE does not exist in digital video. There are no volts. Their request is nonsensical.
Video black in 8-bit is 16. That's it.
Unless you're laying it out to analog tape, there isn't IRE involved.
You might want to ask them what they mean.
Regards,
Chris
Scott Sheriff
on Jun 9, 2011 at 10:54:22 pm
[John Martin] "It's a com. spot for a client out here. A specific delivery spec, it calls for "IRE" standards. I've mostly dealt with broadcast safe mode, not the scopes in FCP, or measuring IRE.
DO you know of a feature (or third party software) to help monitor IRE standards?"
Do you not know what this is? Are you the editor on this project, or perhaps the producer? I would expect an editor to know what this is, and how to evaluate it.
OK, are you delivering for NTSC (that would be weird) or ATSC?
And actually IRE specs can include a lot more than just luma/chroma levels. What about front/back porch, blanking, sync, burst levels, what line test and reference signals are embedded in, etc?
IRE as a unit of measure is one thing, but as a spec or a standard it is a lot more.
Scott Sheriff
Director
http://www.sstdigitalmedia.com
I have a system, it has stuff in it, and stuff hooked to it. I have a camera, it can record stuff. I read the manuals, and know how to use this stuff and lots of other stuff too.
You should be suitably impressed...
Chris Wiggles
on Jun 12, 2011 at 8:25:33 pm
I wish the IRE terminology would just die a horrible death and go away. It has no relevance to anything anymore.
Digital video is digital video. 16 is 16. 235 is 235. There's no IRE involved. Ever.
Regards,
Chris
Rafael Amador
on Jun 12, 2011 at 9:14:01 pm
Those specs are for plain NTSC when broadcasting or printing analog (Betacam, I", U-matic..).
What you have been watching at home for more than 50 years.
You need a video card an an external monitor.
rafael
John Martin
on Jun 13, 2011 at 8:02:36 pm
Thanks.
Jacob Nasim
on Aug 2, 2012 at 6:32:31 am
Here's a thang:
I export SMPTE bars from Avid (601/709) as ProRes(HQ).
I bring that file into FCP 7 and the bars now don't hit 0 and 100.
Is it that FCP scopes which say 0% to 100% actually are saying that is 0-255 RGB?
Any help is greatly appreciated.
Thx,
Jacob
