video plays too fast; information already transferred
jamie adams
on Jun 9, 2011 at 1:34:26 pm
Another issue, how would I correct the problem with footage that has already been log and transferred? The P2 cards have been reformatted and used. Again, 720p 30fps, 1/60th on the shutter.
Thanks in advance
Steve Eisen
Re: video plays too fast; information already transferred
on Jun 9, 2011 at 1:45:43 pm
Do you have audio on your footage? If yes, you undercranked your footage.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
jamie adams
on Jun 9, 2011 at 1:57:50 pm
Yes I have audio. Please offer me a solution. :) Thanks
Jeremy Garchow
on Jun 9, 2011 at 2:01:22 pm
Correct what problem?
jamie adams
on Jun 9, 2011 at 2:18:11 pm
When I play it in the timeline the audio is out of sync. It starts out fine but then gets out of sync. Please help.
Jeremy Garchow
on Jun 9, 2011 at 2:31:27 pm
We are going to need way more info about your system, settings, timeline, etc.
Ben Holmes
on Jun 9, 2011 at 2:40:29 pm
Jamie - if you keep posting the same things multiple times on these forums, you'll run out of friends.
Try to be more precise, and give as much info as you can - clearly you don't know yet which bits of it will be important, so include it all.
Edit Out Ltd
FCP Editor/Trainer/System Consultant
EVS/VT Supervisor for live broadcast
RED camera transfer/post
Independent Director/Producer
http://www.blackmagic-design.com/community/communitydetails/?UserStoryId=87...
jamie adams
on Jun 9, 2011 at 2:58:47 pm
Sorry for any confusion; first timer posting. The info; HVX200, P2 card, Frame size 960x 720, video rate 29.97fps, shutter 1/60th, compressor DVCPROHD720p60, Data rate 7.2mb/sec., Audio rate 48.0KHz, audio 16 bit.
I hope this is adequate. Thanks again and sorry for the mess.
Dave LaRonde
on Jun 9, 2011 at 3:19:17 pm
According to the TWO threads you started on this topic previously, it would seem that you can't accept that you shot at the wrong frame rate.
Go here:
http://forums.creativecow.net/thread/8/1134697
And Here:
http://forums.creativecow.net/thread/8/1134693
...and read carefully.
Dave LaRonde
Sr. Promotion Producer
Ben Holmes
on Jun 9, 2011 at 3:22:36 pm
It sounds as though you are confusing 'shutter' with frame rate. Shutter speed has nothing to do with framerate. You've recorded 720p30, not 720p60 by the sounds of it.
As David says, read both your other threads.
Edit Out Ltd
jamie adams
on Jun 9, 2011 at 3:36:23 pm
I had the rate at 720p, and I cannot re-transfer it; the cards have been reformatted.
Thank you for your advice.
Dave LaRonde
on Jun 9, 2011 at 3:58:28 pm
[jamie adams] "I had the rate at 720p..."
720p WHAT?
The statement above simply says that you shot progressive at a RESOLUTION of 720 vertical pixels.
It says nothing about the frame rate, which you apparently need to learn.
Here's a pop quiz -- when you shoot 720p 60, what's the ACTUAL frame rate: is it 29.97 frames/sec, 60 frames/sec or 59.94 frames/sec?
Dave LaRonde
Shane Ross
on Jun 9, 2011 at 4:51:22 pm
What? The cards have been reformatted? Dude...bad bad bad. That's like capturing tape, and erasing the tape. KEEP THAT STUFF. You backup the P2 contents to hard drives at least. Because when stuff like this happens, and it will, as you know, you can always go back to the originals and reimport. Without them...well, you have a mess to deal with.
For future reference, watch this tutorial. It covers the ENTIRE workflow of backing up tapeless media, to importing it into FCP. Tapeless Workflow for FCP 7 Tutorial
Already imported...sped up...out of sync...originals gone. That's a mess. Wish I had the time, and footage that was messed up in the same way, to help out.
Shane
jamie adams
on Jun 9, 2011 at 5:37:34 pm
Thank you Shane for the link to the Tapeless workflow. I have never encountered this before.
Ben Holmes
on Jun 10, 2011 at 9:16:07 am
[Shane Ross] "What? The cards have been reformatted? Dude...bad bad bad. That's like capturing tape, and erasing the tape. KEEP THAT STUFF. You backup the P2 contents to hard drives at least"
In live broadcast environments, this is more common that anyone would like to admit. P2 cards are expensive, and ingest to a RAID is the best most people manage due to time constraints. It gives me the willies every time. When what you got is irreplaceable (covering a live event) I much preferred a growing shelf of 30 min tapes....
Edit Out Ltd
