 | video plays too fast another issue
on Jun 9, 2011 at 2:27:49 am |
Another issue, how would I correct the problem with footage that has already been log and transferred?
Again, 720p 30fps, 1/60th on the shutter.
 | Re: video plays too fast another issue on Jun 9, 2011 at 3:14:50 pm |
Shane gave you the answer already in the previous thread: you need to retransfer it. You start at Square One.
Or you simply work in the proper FCP edit timeline, which can be established by dragging a current clip into an EMPTY edit timeline, and letting FCP adjust the timeline to the footage when you're prompted to do so.
You shot at the incorrect frame rate. You need to learn the difference between 720 30p and 720 30 pN. I'd say a good, thorough reading of the manual might be in order as well.
Dave LaRonde
Sr. Promotion Producer
