Mid-2011 iMacs - Jumbo frames
Ben Holmes
on Jun 8, 2011 at 3:23:08 pm
Hi all
Can anyone with direct experience confirm that the newest iMacs now support Jumbo frames? I've read comments on here that they do, and Apple says in the most current support doc:
"The Ethernet port supports the configuration of Ethernet frames larger than 1,500 MTU (Maximum Transmission Unit)".
I'm aware previous models (when the Core Duos were still available) did not support this.
Many thanks.
Ben
Edit Out Ltd
FCP Editor/Trainer/System Consultant
EVS/VT Supervisor for live broadcast
RED camera transfer/post
Independent Director/Producer
http://www.blackmagic-design.com/community/communitydetails/?UserStoryId=87...
Ben Holmes
Re: Mid-2011 iMacs - Jumbo frames
on Jun 8, 2011 at 5:25:23 pm
For anyone interested where the rather vague quote above came from:
http://support.apple.com/kb/HT4619
Ben
Edit Out Ltd
Tim Ward
on Jun 9, 2011 at 1:32:30 pm
We've testing this at Small Tree. The new iMacs do, in fact, support jumbo frames. Makes the iMac a much less expensive good option to a MacPro for FCP utilizing ethernet shared storage.
Ben Holmes
on Jun 9, 2011 at 2:28:11 pm
Ah - brilliant, if Small Tree say so, I know it must be true! Thanks Tim, you've saved me a load of worry about purchasing. Now, if only you guys were based in the UK...
Thanks again!
Edit Out Ltd
