does shure x2u work with fcp
jurriaan van der kamp
on Jun 7, 2011 at 10:18:30 am
Hi
i was wondering if a shure x2u work with fcp's vo tool.
That instead of the internal mike you now can use a xlr condenser mike.
I now use the digidisighn mbox and it works fine with leopard but to let it work with snowleopard
seems to be a hassle.
So does the shure x2u work with fcp does it mirror th quality you get from say my mbox?
thanx. jur
André Engelhardt
Re: does shure x2u work with fcp
on Jun 7, 2011 at 7:03:20 pm
Hi Jurriaan,
the Shure X2u should work just fine with Snow Leopard! In the VO tool's source drop-down menu just select the "Shure Digital" input and you're all set.
As far as quality is concerned I doubt you will hear much of a difference for voiceovers, so you should be fine.
Good luck!
André
Sound, Music, Film, Photo
http://www.andreengelhardt.net
Andrew Rendell
on Jun 8, 2011 at 3:57:23 pm
I've got a Lexicon Alpha and a Samson Go Mic and both of those worked straight away without a hitch (FCP7, Snow Leopard), so I'd be surprised if there was a problem with the Shure.
