J-K-L Suddenly Won't Scrub!
Don Smith
on Jun 6, 2011 at 9:49:26 am
Suddenly, holding the K and pressing either J or L does not scrub on my Final Cut system. I've trashed the prefs and I've put the keyboard mapping back to default. Holding K and pressing either J or L simply resumes playing at normal speed (reverse or forward depending on J or L). Any clues?
Jerry Hofmann
Re: J-K-L Suddenly Won't Scrub!
on Jun 6, 2011 at 12:05:03 pm
Check the keyboard layout, and if it's correct, try trashing preferences. K+L should play forward at 50% speed... K should be set to be stop.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
