Audio Problems with FCP
Richard Pengelly
on Jun 2, 2011 at 4:25:14 pm
Sometimes after editing to a music track the music skips and plays a different portion then what I originally cut in. I match frame at the point where the problem is and it plays fine in the preview window.Then I have to cut the music back in and then it is fine after that. This has messed up some of my exports as I was going with the assumption that every thing was fine and still in sync.
FCP Ver 7.0.3
The Music is from A stock Music CD
Format PCM,16bit big-endian signed integer, 2 Channels 44100HZ
I checked the Timeline Settings and it is set to 48khz, 16bit, Channel Grouped. Should I have the sequence KHZ matched to the audio track?
Also occasionally I get a horrible audio overload when playing these tracks. Sounds like A freight train and has almost blown the Logitech speakers and my ears.
Funkin it up Old School
Shane Ross
Re: Audio Problems with FCP
on Jun 2, 2011 at 4:37:58 pm
[Richard Pengelly] "Format PCM,16bit big-endian signed integer, 2 Channels 44100HZ"
That's your problem. Audio needs to be AIFF or broadcast WAV, and 48khz, 16 bit stereo...
Shane
Andrew Rendell
on Jun 2, 2011 at 5:12:55 pm
As Shane says, it's because it's at 44.1kHz, you need to change it to 48k (I have a Compressor Droplet on my desktop for that very thing, so I never bring in anything at 44.1k).
The overload is because CDs are normalised to peak digital level, which is way higher than the levels used in tv. I normally lower anything from CD by 10 or 15dB before I even play it.
