Adding Watermark Through Compressor
Greg Burke
on Jun 1, 2011 at 8:46:22 pm
IS there a way to add a watermark while sending files though COMPRESSOR? I ask because I have to Export Multiple videos in 3 formats HD, SD and HD w/a watermark (in the hundreds) and Dont wanna have to go into FInal Cut And Put it in manually over 100 times. Any Suggestions? Thanks.
Shane Ross
Re: Adding Watermark Through Compressor
on Jun 1, 2011 at 9:01:24 pm
Yes. In the INSPECTOR in Compressor, there is a tab for FILTERS. WATERMARK is one of those filters. Select that, then select the graphic to be used as the water mark.
BINGO was his name-o.
Shane
Greg Burke
on Jun 1, 2011 at 9:06:57 pm
OMG YOUR AMAZING MR ROSS!!!!! Thank you! IM not on my edit machine right now (on my iphone), is there a way to Control where the Graphic is placed? and How big it is?
Cody Walters
on Jun 1, 2011 at 9:40:35 pm
Greg,
Once you check the Watermark filter, you will see a Position drop down (center, lower left, lower right, etc.), scale by parameter and alpha parameter.
Cody Walters
JW Studio LLC
Houston Video Production
Houston Wedding Videographer
Final Cut Studio 3
Adobe CS5 Master Suite
Panasonic HVX-200
Canon 7D
Amy Taylor
on Jul 24, 2013 at 5:26:21 pm
Here's a related question — How do I add a watermark/logo using compressor 4 settings through FCPX? When I compress the video in compressor, the watermark shows up fine. But when I do it in FCPX using compressor settings, it doesnt do anything.
