Can you mix ProRes flavors in the same project?
Kim Fox
on Jun 1, 2011 at 8:02:58 pm
Hi all,
Project was shot in ProRes4444.
Most of the footage was transcoded to ProRes 422(LT) for offlining.
A few clips will not transcode.
However, the "trouble" clips will import into and play in a separate project I created in FCP.
Is is possible to just use the 4444 clips in the project with the 422 clips, just for the offline?
Thanks so much!
Kim
Rafael Amador
Re: Can you mix ProRes flavors in the same project?
on Jun 1, 2011 at 8:24:59 pm
No problem to mix both on the same sequence and no problem to relink the media.
rafael
http://www.nagavideo.com
