Import P2 into FCP w/o p2 reader
Chris Balogh
on May 31, 2011 at 7:48:18 pm
I have OS X ver 10.5.8 and FCP 6 as well as compressor, just keep this in mind, may be able to use this...
So I have footage (mxf files), they are locked. How do I import them into FCP? The driver on Shane Ross tutorial's page, doesn't work. Please help. I have tried to install drivers, but no such luck - they are from other sites.
Shane Ross
Re: Import P2 into FCP w/o p2 reader
on May 31, 2011 at 7:52:27 pm
Do you have the FULL P2 card file structure? Or only MXF files in VIDEO or AUDIO folders? Or both? You watched my tutorial on this? Tapeless Workflow for FCP 7 Tutorial
You only need the driver to get the mac to see the P2 card. After that, you offload the entire card, then use Log and Transfer a the TOP level of that backup..the folder you backed up into. Don't go digging to the MXF level.
© 2018 All Rights Reserved
