avi file in fcp
Jimena Mora
avi file in fcp
on May 30, 2011 at 8:50:27 am
Hello I recorded a video with a photo camera - Canon S5IS at frame size 640x480 30fps. When I import the files into the Final Cut, I get black stripes in the right and left sides of the image. I have already tried changing the frame size in the sequence and audio video settings but still get the same result. If I change into anamorphic I get a stretched like image with no black stripes on the sides or up and down. I think it is simple to solve but I don't know which setting to change to solve it.
Thank you in advance
Shane Ross
Re: avi file in fcp
on May 30, 2011 at 5:38:43 pm
You have to convert the file to an editing format. AVI isn't something FCP works with. Use Compressor to convert it to DV/NTSC.
© 2018 All Rights Reserved
