Mixed Format Workflow - SD & HD
Sascha Engel
on May 29, 2011 at 2:16:17 pm
Hi Everybody,
I am currently editing a Mocumentary, which consists of DV-PAL SD Footage 25p from a Panasonic DVX100B mixed with Footage from a small HD Consumer Camcoder (Files been given to me, transcoded into Apple ProRes HQ) and Foptage of the GoPro mini HD Cam (currently imprted as MP4s).
Now my Qs:
1. Into what should I convert my GoPro Footage to (is connected with Q 2:)
2. What is the best Timeline Format to edit my project in? Making a Timeline according to the SD 25p Footage of the DVX100B and downsizing the ProRes HD clips when I through them in, or is that a shame, when CC, better to use the HD footage in native size?
3. When converting the GoPro Footage into e.g. Apple ProRes, is Episode a good App to go and Batch them all through there?
Thanx a lot.
Sascha
Shane Ross
Re: Mixed Format Workflow - SD & HD
on May 29, 2011 at 6:27:50 pm
[Sascha Engel] "1. Into what should I convert my GoPro Footage to (is connected with Q 2:)"
ProRes. YOu have been hanging out here long enough to know that by now Sasha... :)
[Sascha Engel] "2. What is the best Timeline Format to edit my project in?"
What does the MAJORITY of your footage consist of? What is your final deliverable going to be?
[Sascha Engel] "3. When converting the GoPro Footage into e.g. Apple ProRes, is Episode a good App to go and Batch them all through there?"
Compressor batches...
Shane
Sascha Engel
on May 29, 2011 at 7:27:33 pm
HI Shane,
yes, you are right, I thought already ProRes, but I never worked with GoPro footage before - and wanted to be sure.
The Material is for 60% SD DV-PAL Footage and 40% GoPro and ProRes Converted Footage from a Consumer HD Camera.
I know, that Compressor had a Batch Capture, but I just read a lot about Speed & Quality issues in Comparison to e.g. EPISODE - tried Episode on a friend's machine and I was blown away - the speed difference is mind blowing. EPISODE versus Compressor is like Ferrari versus VW Beatle!
Greetz,
Sascha
Sascha Engel
on May 29, 2011 at 7:28:39 pm
...ah and final output:
Projection on a big screen during a theatre show - most likely from a computer or DVD Player.
Sascha
Shane Ross
on May 29, 2011 at 8:03:40 pm
Well, unless you can upconvert the SD to HD via hardware I'd stick with SD. But not DV. Prores Pal or DV50
Shane
Sascha Engel
on May 29, 2011 at 8:54:45 pm
Hi Shane, thanx a lot. DV ProRes it is.
Sascha
Michael Gissing
on May 29, 2011 at 11:08:02 pm
Stick with a ProRes timeline, not DV50. That way all your material including the converted DV to ProRes footage should all be upper field. A Dv50 timeline will mean lower field sequence with upper field footage which is a total pain.
Sascha Engel
on May 30, 2011 at 3:23:51 am
I think, that wouldn't be a problem, since it's all 25p footage, no interlaced material at all.
Sascha
