Final cut can't open!!!
samir kassab
on May 29, 2011 at 10:46:14 am
hi guys
i downloaded the trial version of Avid media composer 5.5 on my macbook pro.now when i open final cut it gives me a message that final cut quit unexpectedly,cuz of avid AVCHD codec! i uninstalled Avid and its codecs , trashed the FCP preferences , restarted and still getting the same message!all the other FCS applications are working perfectly though !
is there any tips before i uninstall my FCS and reinstall it again ??
samir kassab
Re: Final cut can't open!!!
on May 29, 2011 at 1:26:52 pm
sorry i was i a hurry , i wrote the error msg wrong! it goes "final cut pro quit unexpectedly while using the AvidAvdAVdncodec plug-in" .... i removed FCS and reinstalled it again ... still getting the same message!
this is getting really annoying
any help please!
Everest Mokaeff
on May 29, 2011 at 1:54:45 pm
Instead of re-installing FCS try to remove plugin that generates error.
Free-lance fcp editor in Moscow
http://www.mokaeff.com
samir kassab
on May 29, 2011 at 1:57:38 pm
i did that ... is there any other place i should search other the plug-in folder inside the application's "show content "??
samir kassab
on May 29, 2011 at 3:06:09 pm
thanks Everest,i've found it !
its was neither in the application's content folder , nor in the library/supporting files/fcp supporting files/ nor in the avid plug ins .... it was simply in the library / quicktime folder :)
thanks again
