Multiple exports of the same file as ProRes= Loss of quality?
George Ovcinikov
on May 29, 2011 at 1:55:14 am
Hi, I was not sure under which category to post this question, because it relates to more than just Final Cut Pro. I am sorry I chose the wrong one.
I am working on a short film which includes a lot of shots that need to be worked on with After Effects. I realised that i will have to export the shots several times: from final cut to after effects to do effects, then from after effects back to FCP, then once the edit is complete i will export the whole sequence again and import it into after effects to do final color correction. The final Quick Time file will be exported from AF.
My question is: Even tough I export as ProRes 422 every time. Will these multiple exports diminish the quality of my clips?
Thank you.
George.
Andrew Rendell
Re: Multiple exports of the same file as ProRes= Loss of quality?
on May 29, 2011 at 6:37:58 am
If you are always in ProRes422 there won't be any inherent loss of quality by passing the shots through different software. You get a loss of quality if you transcode between different codecs. (It's possible that you might degrade some aspects of picture quality in doing some effects, but that's a different issue).
George Ovcinikov
on May 29, 2011 at 12:06:51 pm
Thank you for your answer.
Phew, now all my exporting worries are gone.
