Pro res rendering problem
Matthew Levett
on May 27, 2011 at 5:53:48 am
Hi there,
I've down converted some H.264 files in Pro res.
Here are the stats...
Format - Apple ProRes 422, 480 x 270, Millions
16-bit Integer (Big Endian), Stereo, 48.000 kHz
FPS - 25
SIZE - 480 x 270 pixels (Actual)
Problem is , when I put them in FCP 7 sequence and put any effects (slow mo, dissolve) the red comes up and i have to render all the time. can i change something in the settings? Any suggestions?
Everest Mokaeff
Re: Pro res rendering problem
on May 27, 2011 at 7:00:18 am
Time-line upper left corner: Switch Safe RT for Unlimited RT. By the way, this is bad resolution you are gonna edit there. Try to use more conventional (SD/HD) formats as your footage sources.
Free-lance fcp editor in Moscow
http://www.mokaeff.com
Shane Ross
on May 27, 2011 at 7:21:28 am
480x270 is not a real time pixel aspect ratio. FCP is designed to work with broadcast video formats. And those frame sizes are 720x480...or in PAL land, 720x576. Yes, you footage is ProRes, but the dimensions are the issue.
If you want to work without much rendering, you need to convert to the PAL SD dimensions.
Shane
David Roth Weiss
on May 27, 2011 at 3:04:46 pm
[Matthew Levett] "I've down converted some H.264 files in Pro res."
No, you either transcoded or possibly, in this case at least, up-converted.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
http://www.drwfilms.com
Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
