Converting Still Image Size In Sequence...
Gib whitney
on May 24, 2011 at 10:50:22 pm
I'm creating a stop-motion project and have scores of photos already positioned in my timeline. I have almost completed the project but can no longer render due to memory issues. The stills are 5184x3186 and more than likely need to be compressed into 1920x1080 - just wondering if there is a painless way to accomplish this without having to do it still by still in Photoshop, or without having to redo the sequence?
Bret Williams
Re: Converting Still Image Size In Sequence...
on May 25, 2011 at 3:22:31 am
I have done something similar. You can use a batch on PS to resize all the images. First make a backup of the images. Then run a batch resize on the images. Generally in PS you'd have the images in a folder and run the batch on the folder. Just have it save right over the old files (hence the backup) and FCP will see the changes and relink. But they'll be real tiny now. Rescale one to fit correctly and copy it, then paste the applicable attributes (scale & maybe distort) to all the others at once.
Gib whitney
on May 26, 2011 at 11:11:45 pm
Thank you very much for this info...it was most helpful!!!
