double system sync
Jim Curtis
double system sync
on May 24, 2011 at 4:32:27 pm
I'm cutting using double system sync. Video is from a 5D; audio is from a Zoom recorder.
After syncing, is there a way to lock the double system tracks in sync with the video?
The Modify > Mark In Sync command isn't doing it.
I don't want to Nest because I need access to the discrete audio tracks.
I take it that this feature will be in FCP X, but I need it now. Am I SOL?
Jim Curtis
jamesphilipcurtis.com
MacPro (Harpertown-Early 2008) 2x4 3GHz; 32G RAM all the same brand; 10.6.3; QT 7.6.6; FCS3; Kona LHi in PCI slot 3 (8.1.1); Primary display: 30" ACD; Monitoring: Kona LHi SDI to AJA HDP2 converter to HDMI on the HP DreamColor.
John Pale
Re: double system sync
on May 24, 2011 at 4:50:20 pm
Look up Merge Clip in the Help files
Jim Curtis
on May 24, 2011 at 5:10:05 pm
Merge Clips isn't working for some reason, but Link Clips is, and that's actually what I wanted to do. I must have had a brain lapse. I know about Link Clips, but I guess I was thinking that it only worked for AV clips that had the audio and video together, and it was a method of unlinking them.
Anyway... thanks for your reply, John. It jump-started me where coffee did not.
John Pale
on May 24, 2011 at 5:38:49 pm
Merge clip does not work in the timeline. You do it in the Browser and Viewer.
