Replace audio Cineform track in FCP - unnecessary encode
Anmol Mishra
on May 24, 2011 at 6:07:32 am
Hi! I am using pluraleyes to replace an audio track from the camera with one recorded off camera. I have the camera file aligned with the off-camera audio.
Now I proceed to delete the audio from the camera file.
At this time when I export, (keeping the same settings) FCP should just re-encode the audio. This should not be more than a few minutes.
I get 7 minutes on a quad core for a 2 min Cineform file. This leads me to believe that FCP is re-encoding the original file.
Is there a way to prevent this ? To force a "Smart Encode" where only the audio is encoded ?
Jerry Hofmann
Re: Replace audio Cineform track in FCP - unnecessary encode
on May 24, 2011 at 11:55:09 am
Why export the files? Just merge the clips instead.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
