Codec Not Found message
Marco Aguilar
on May 23, 2011 at 5:43:15 pm
I am attempting to export a self contained quicktime file of a 90 min feature film for a friend of mine. The frame rate is 23.98. Pixel Aspect Ratio is 1280x1080. The Quicktime Video settings for some odd reason are 1080p30 which I find odd because the sequence settings are 23.98. I keep getting two error messages. One is OUT OF SPACE which is impossible because I have over a TeraByte of space. Than it is followed by this message. CODEC NOT FOUND. YOU MAY BE USING A COMPRESSION TYPE WITHOUT THE CORRESPONDING HARDWARE CARD. Any suggestions? Thanks.
Shane Ross
Re: Codec Not Found message
on May 23, 2011 at 6:02:56 pm
Have any stills in the timeline? are they in the CMYK Color Space rather than RGB? That's what is up when I get that message. And, any of these stills over 4000 pixels?
Sam Cole
on May 24, 2011 at 4:00:05 am
FCP will show those odd error messages when it runs out of memory.
The work around is to close FCP and then restart and do your export immediately.
I don't know why it can't just say "out of memory" rather than "codec error" or "out of disc space" or even worse "general error".
I wonder what all the new workarounds are going to be with the "X factor"
Sam Cole
On line Mastering Facility
FCP, Avid, Adobe
Sydney, Australia
© 2018 All Rights Reserved
