Sending project sequences to Soundtrack
Paul Donahue
on May 23, 2011 at 9:08:33 am
I have a timeline made up of 10 individual sequences. I would like to send the audio from this project to Soundtrack. Is there a way to do this without having to send the audio of each sequence individually?
I am using FCP 6.0.6 on an iMac with Mac OS 10.6.7.
Thanks in advance.
Jerry Hofmann
Re: Sending project sequences to Soundtrack
on May 23, 2011 at 2:21:26 pm
I'm not clear on what you have going there, but if they're all in the same sequence, then you could send them all at once.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Paul Donahue
on May 24, 2011 at 6:18:17 am
I have a project timeline that is made up of 10 chapters and each is a separate sequence. I have tried to send the project to Soundtrack but to no avail. I think to do the music mix that I will send them individually and link them together unless I can figure out another way to get them altogether to Soundtrack.
Paul Donahue
Media Eye
http://www.mediaeyemedia.com
Jerry Hofmann
on May 24, 2011 at 12:02:35 pm
I'd think that it should work OK...
What happens when you select all, and send to Soundtrack Pro? Nothing?
Jerry
Current DVD:
