audio/video settings
Matthew Levett
on May 23, 2011 at 2:01:10 am
New to this. Ive been sent footage in a lower res to edit via dropbox. Originally shot with canon 5d. Im not sure what setting I should use. When I drop it into my sequence on fcp 7 I get "change sequence setting to match clip setting" - I click yes. The footage plays fine until I slow it down, or use simple transitions - then its red and I have to render it all the time. Any help would be appreciated.
Cheers,
Matt
Eric Strand
Re: audio/video settings
on May 23, 2011 at 3:50:27 am
Can you open the files in Quicktime and find out the type of file you are working with? Go to Window(I think) > Movie Inspector; under the format section it will say what types of files you are working with.
Jerry Hofmann
on May 23, 2011 at 4:38:02 am
What format are the clips you've down converted?
They should be ProRes files. Some codecs don't work with RT extreme for real time playback of unrendered effects. Sounds like you're working with the wrong codec.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Matthew Levett
on May 23, 2011 at 6:02:27 am
The format of the clips is H 264.
Is there something in the set up I'm missing?
Jerry Hofmann
on May 23, 2011 at 2:23:52 pm
FCP 7 doesn't support H.264 files. You need to transcode your footage to ProRes files.
Jerry
Current DVD:
Matthew Levett
on May 25, 2011 at 12:17:53 pm
Thanks for that Jerry.
Below is all the information about the clip
FORMAT : H.264, 480 x 270, Millions
AAC, 2 channels, 48000 Hz
FRS :25
CURRENT SIZE : 480 x 270 pixels (Actual)
Im having trouble matching FCP sequence setting with the down conversion.
Using MpegStreamclip - Whats the best Pro Res setting to use for the down conversion? Do I leave it the same size as well?
Thanks.
