1080, 23.98 compressor convert to 1080, 29.97
Sarah Taylor
on May 22, 2011 at 12:20:21 am
Does anyone have ideas on the proper compressor settings needed to convert a 1080,23.98 NDF timeline to a 1080, 29.97 DF?
Sarah
Jerry Hofmann
Re: 1080, 23.98 compressor convert to 1080, 29.97
on May 22, 2011 at 12:25:27 am
Can't change the editing timebase of a sequence... what is it that you're trying to do? What's you're deliverable. There's a better way I'll bet.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Sarah Taylor
on May 22, 2011 at 12:26:59 am
We want to edit in the native 23.98 but the broadcast deliverables are 29.97. What would you suggest?
John Pale
on May 22, 2011 at 3:27:13 am
The best way would be to have your capture card (Kona, Decklink, Matrox) add the pulldown on output to tape. If you do not have one, then you can do it in Compressor.
You did not state your editing codec, but If you edited in ProRes @23.98, just use the ProRes preset in Compressor. Change the frame rate to 29.97 and Compressor. You do not need to change the Frame Controls to Best...just leave it set to fast. Compressor will add the proper pulldown. When you finish encoding, bring the file into FCP and use the modify timecode command to change to DF.
Sarah Taylor
on May 22, 2011 at 4:06:44 am
Thanks so much!
I am editing in ProRes so I'll try this for sure!
