Log and Transfer problems
Paul O'Connell
on May 20, 2011 at 9:44:25 pm
Hello
It seems I'm having intermittent problems with Log and Transform. Which is it is not transferring the whole clip. For example a 7:52 will have only 5:32 of it captured. I had tried unchecking "remove advance pulldown and duplicate frames" that someone had suggested. It worked at first but then the problem came back. It's basically a 50/50 shot if it's going to be successful.
Background:
FCP 7.0.3
O.S 10.5.8
I'm transferring Canon 5D clips(H.264) and importing them Apple pro res 422. I'm also changing the name of the clip
Thank You
Paul
Chris Tompkins
Re: Log and Transfer problems
on May 20, 2011 at 10:30:45 pm
Does the footage span 2 or more cards?
Chris Tompkins
Video Atlanta LLC
Ernie Santella
on May 21, 2011 at 5:38:53 am
I'm transferring 5D files right now. I had a bit of the same problem. I noticed that if I did anything else in FCP while importing (Like look at another clip I just transferred) it would chop off the clip that was currently being imported. So, now I just let it do it's thing without interuption. Worth a try.
Ernie Santella
Santella Productions Inc.
http://www.santellaproductions.com
Paul O'Connell
on May 21, 2011 at 2:49:08 pm
@ Chris-It's actually just from one card
Thanks Ernie- I'll just leave FCP alone while transferring
Ernie Santella
on May 21, 2011 at 3:42:55 pm
Paul, report back if it works. I'd like to know if that issue was just me.
Ernie Santella
John Pale
on May 21, 2011 at 4:09:54 pm
This has been posted a number of times....(Shane Ross, maybe?)
Yeah, let FCP do its thing and don't try to multiple-task.
I can attest that worked for me. No more incomplete clips.
Paul O'Connell
on May 23, 2011 at 5:09:13 pm
So I imported the 5D footage without a hitch after leaving FCP alone
So definitely do not do other tasks while importing with Log and Transfer.
I do wonder why FCP makes it possible to do other tasks in the first place. Do they eventually want to have the Log and Transfer going in the back ground while other work is done?
John Pale
on May 23, 2011 at 6:14:07 pm
Canon writes the plugin, so maybe the fault lies there.
Steve Fanale
on Jul 4, 2012 at 7:39:07 am
Tried the above still having issues - any suggestions
