HD work flow
Morrie Mayer
HD work flow
on May 20, 2011 at 8:15:37 pm
I have no problem importing canon mxf files using prores422; however when setting up the sequence the clip doesnot play back on a LED 1080p 120 hz screen using the Black Magic Intensity Pro card and frame rate of 30. The clip plays nicely at 23.98 fps. I am using prores422 as the sequence compressor.
What should I do?
Chris Tompkins
Re: HD work flow
on May 20, 2011 at 10:35:34 pm
Your sequence AND clip settings must match.
Your Black Magic card settings must match your sequence for play out.
Chris Tompkins
Video Atlanta LLC
© 2018 All Rights Reserved
