Text Tool: Title Crawl
Sascha Engel
on May 18, 2011 at 7:00:10 pm
I have to run titles on the bottom of the screen (from left to right / hebrew).
Unfortunately, it runs a bit staccato, not so smooth, which makes it hard to read.
Any other Generator to get a better result in FCP, or a tip, how to smoothen the Crawl Title Generator?
Thanx.
Sascha
Rafael Amador
Re: Text Tool: Title Crawl
on May 18, 2011 at 8:38:34 pm
Hi Sascha,
I haven't use a crawl since ages, but I would try the FCs "Boris Crawl".
rafael
http://www.nagavideo.com
Sascha Engel
on May 18, 2011 at 9:32:50 pm
I don't have Boris :-(
Any idea what else to do?
Sascha
Rafael Amador
on May 18, 2011 at 9:38:34 pm
[Sascha Engel] "I don't have Boris :-("
yes, you have it, or you should have it because comes bundle with FC since I can remember.
Look in the text tools; you should have a Boris folde.
rafael
Sascha Engel
on May 18, 2011 at 9:48:52 pm
Yup, found it.
And amazing enough: It even has a direction change for Hebrew!!!!! :-)
Thanx a Lot!
Sascha Engel
on May 18, 2011 at 10:02:33 pm
HI Raphael,
I still havve the problem, that despite all the fancy options - the text is quiet unreadable.
Any special adjusyment I might not be aware off?
Sascha
Rich Rubasch
on May 18, 2011 at 10:31:08 pm
Is it rendered? Do you have a green line or orange?
What are the sequence settings?
Rich Rubasch
Tilt Media Inc.
Video Production, Post, Studio Sound Stage
Founder/President/Editor/Designer/Animator
http://www.tiltmedia.com
Sascha Engel
on May 19, 2011 at 5:33:35 am
Yes, it is rendered. The Sequence Settings are Full HD size (1920*1080), ProResHQ.
Sascha
Rafael Amador
on May 18, 2011 at 10:37:30 pm
Are you working in p24/25?
Which kind of stuff?
rafael
Sascha Engel
on May 19, 2011 at 5:34:36 am
Yes, it is 25fps Progressive. ProResHQ Codec.
Rafael Amador
on May 19, 2011 at 3:58:09 pm
Sascha,
p25 will makes any animation more choppy than i50 or p50. I guess that a fast Crawl may look very jumpy.
But not sure if that is the problem when you say that the picture is unreadable.
The Boris filter has a "De-flicker" filter, but that should works for rolling text.
I would try something like applying some (.5) Horixontal Blur to the text.
Without having a look is difficult to imagine the real issue.
rafael
Sascha Engel
on May 19, 2011 at 4:50:13 pm
Yes, I think you right - it might be the 25p frame rate - specially for Crawl text.
I will try the horizontal blur - maybe that helps.
Thanx a lot.
Sascha
