Tapes not reading data...
Matt Hannon
on May 15, 2011 at 1:22:52 pm
I've just returned from a trip to Indonesia, whereby I did some filming in the jungle as well as beaches.
I have already captured 99% of the 23 hours that I shot whilst over there, but there is one tape which for some reason or another, cannot be read when trying to capture?!
I have tried capturing on several different cameras, as well as a deck... none of them are reading it? Its not even reading any timecode??
I know there is footage on there, as I labelled the tape.
I am also experiencing this 'data loss' for shorter periods on other tapes, same thing happens whereby the timecode disappears also.
The tapes I used were JVC ProHD 63 min.
Any ideas/previous experience would be greatly appreciated.
thanks
Bret Williams
Re: Tapes not reading data...
on May 15, 2011 at 2:52:13 pm
Sounds like dirty heads. Playback head if you're lucky, but since it's on all playback machines, it may have been record head in camera.
Matt Hannon
on May 16, 2011 at 4:58:47 am
Thanks Bret,
This did cross my mind and I have run a head cleaner, through to no avail.
Will continue to research solutions... fingers crossed!!
cheers,
m
