Aspect ratio issues
Andreas Jensen
Aspect ratio issues
on May 12, 2011 at 8:50:58 am
Hi.
I've run into a little problem.
I'm working with some media in DV Pal 720 x 576
When i export from Final Cut pro it seems to make it 787 x 576.
I've uploaded screen shots for my sequence settings my export settings and the info of the final export.
Can someone please help me understand. Is it some kind of bug in FCP or is it me who once again needs an explanation of aspect ratio?
Bouke Vahl
Re: Aspect ratio issues
on May 12, 2011 at 11:34:52 am
Don't worry, the files are fine.
It's QT who is messing things up, it shows you the display aspect ration, not the actual aspect.
(and it takes non-square pixels on a computer monitor into account...)
If you send this to another facility, you'll be fine.
Bouke
http://www.videotoolshed.com/
smart tools for video pros
David Roth Weiss
on May 12, 2011 at 11:54:11 am
To add to what Bouke said, anamorphic SD in PAL is recorded at 720x576, but displays at 787x576. So, you're seeing one reference to the actual frame dimensions and one reference to the display dimensions.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
http://www.drwfilms.com
A forum host of Creative COW's Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
Andreas Kiel
on May 12, 2011 at 12:47:01 pm
Just for the records.
QT is not really messing up the things.
It's about the never ending story of signal transmission and this in mind mixing the analog versus digital formats.
The standard is/was to have vertical blanking for each video line (how much is also a point of discussion).
The digital non square 720 from PAL will we corrected to 768 square.
With blanking an often used value is 2.5% so you will get 768*1,025 which results in 787.2.
Anyway the file is okay.
Andreas
Spherico
http://www.spherico.com/filmtools
