Adding keyframes at the end of clips - can't see what i'm doing.
Olly Lawer
on May 10, 2011 at 3:54:55 pm
This has also bugged me for a long time. It's obviously my day for trying to solve annoying things.
When I add keyframes to a clip in FCP, I can see on the Canvass the adjustments I make on the Viewer. With one exception. If I want to add a keyframe to the last frame in the clip, I press the down arrow key, which takes me to the next clip - then click back one and double click the clip I was working on in the timeline.
There must be an easier way?
Olly Lawer
Chris Morlang
Re: Adding keyframes at the end of clips - can't see what i'm doing.
on May 10, 2011 at 5:15:54 pm
Double click the clip you want to edit and hit Shift+O to take you to the out point
~Chris Morlang~
Olly Lawer
on May 10, 2011 at 5:29:56 pm
Thank you!
Olly Lawer
