finishing sequences within fcp
dan crouch
on May 5, 2011 at 5:39:26 pm
I have just finished cutting a movie trailer for cinema and for internet.
There is no money for an online and colour grade so I am delivering the quicktime direct to client.
As I can't have an online to check the peaks etc of the luminance levels etc, is there a way in fcp that will make everything legal?
There are a few negative images that flash up for example, and I need to make sure it doesn't fail a tech review.
Any advice on this would be greatly appreciated.
Thankyou in advance.
Dan.
Doug Beal
Re: finishing sequences within fcp
on May 5, 2011 at 6:17:47 pm
depending on your graphics card the scopes in FCS 3 are very close. That should give you an idea of what's goin on.
check effects>color correction> Broadcast safe filter
Be aware that "everything" legal would include audio levels. often overlooked
Doug Beal
Editor / Engineer
Rock Creative Images
Nashville TN
dan crouch
on May 5, 2011 at 6:25:43 pm
Thank you for post.
Does that mean I simply select whole of video layer and
apply effect and render it.
Cheers,
Dan
Dave LaRonde
on May 5, 2011 at 7:20:34 pm
If the levels change from shot to shot, fix individual shots. If it's all one big file, use the blade tool to split it up.
Dave LaRonde
Sr. Promotion Producer
