mixing 30 fps and 29.97 on a timeline
tad newberry
on May 3, 2011 at 12:06:20 am
Chopping together what is mostly Pro Res 422 1920 x 1080 29.97fps footage with a few shots from a FlipCam. The FlipCam is shooting native 1280 x 720 30fps H.264 (mp4) files, and i had been converting them to the same Pro Res 422 flavors as the rest of my shots. My question: does it make any difference if i convert them to 29.97 or just leave them at 30? I've done tests and see no discernible difference.
thanks for helping out a bonehead!
__________________________
FCS3
2.66 GHz Quad-Core Mac Pro
6GB RAM
NVIDIA GeForce GT 120
...and a few TeraBytes o' storage
(then it's on to PetaBytes, ExaBytes and MosquitoBytes!)
Rainer Wirth
Re: mixing 30 fps and 29.97 on a timeline
on May 3, 2011 at 12:59:33 pm
fiddling around makes some things even worse than better. If it's working stick with it. It saves you time nad you might end up with the result you just have.
Rainer
