New occurrance, old issue
Eric St. John
on May 1, 2011 at 10:50:11 pm
I assure everyone I've spent the last three days Googling and reading. If this definitely redundantly recurring subject irks you, please forgive me. I'm posting here in hopes that someone besides the person writing the following listed blog can offer some insight into what I've found. This is the comment/question I originally wanted to post to the blog on how to solve the great Qmaster/Compressor snafu at:
It's still having a server error so I can't post there. Please bear with me, okay? Thanks!
After attempting the manual start and some other entering in Terminal I discovered that my qmasterd file is missing.
"5/1/11 2:30:16 PM Compressor[764] NSDocumentController Info.plist warning: The values of CFBundleTypeRole entries must be 'Editor', 'Viewer', 'None', or 'Shell'."
I ran Console like someone else had and found this some thirty-two times consecutively:
"5/1/11 2:30:16 PM Compressor [764] NSDocumentController Info.plist warning: The values of CFBundleTypeRole entries must be 'Editor', 'Viewer', 'None', or 'Shell'. "
And then lastly:
"Warning once: This application, or a library it uses, is using NSQuicDrawView, which has been deprecated. Apps should cease use of QuickDraw and move to Quartz."
The StartupParameters Plist showed this:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple Computer//DTD PLIST 1.0//EN" "">
Qmaster services
Starting Apple Qmaster services
Stopping Apple Qmaster services
Qmaster services
And finally, the qmaster terminal start log showed this:
"Last login: Wed Apr 27 22:15:57 on ttys000
mac2s-power-mac-g5-48:~ mac$ cd /Library/StartupItems/Qmaster
mac2s-power-mac-g5-48:Qmaster mac$ sudo /Library/StartupItems/Qmaster/Qmaster start
Starting Qmaster services
mac2s-power-mac-g5-48:Qmaster mac$ /Library/StartupItems/Qmaster/Qmaster: line 12: /usr/sbin/qmasterd: No such file or directory
Last login: Thu Apr 28 07:53:03 on console
mac2s-power-mac-g5-48:~ mac$ cd /usr/sbin
mac2s-power-mac-g5-48:sbin mac$ qmasterprefs -list
-bash: qmasterprefs: command not found
mac2s-power-mac-g5-48:sbin mac$ cd /usr/sbin
mac2s-power-mac-g5-48:sbin mac$ "qmasterprefs -list"
-bash: qmasterprefs -list: command not found
Last login: Thu Apr 28 13:16:43 on ttys000
sanjuan:~ sanjuan$ ls -l /Library/Application\ Support/Apple\ Qmaster/
total 56
-rw-r--r-- 1 root admin 234 Feb 3 2008 QmasterApplications.plist
-rw-rw-rw- 1 root admin 267 Feb 3 2008 qmasterconfig
-rw-rw-r-- 1 root admin 267 Jul 5 2005 qmasterconfig.default
-rw-rw-rw- 1 root admin 4722 Apr 27 15:53 qmasterservices.plist
-rw-rw-r-- 1 root admin 2057 Jul 5 2005 qmasterservices.plist.default
-rw-rw-r-- 1 root admin 1318 Jun 27 2005 transcoderx.plist.default
sanjuan:~ sanjuan$"
I've downloaded Pacifist and have the "how to reinstall this via the Compressor Repair site" page open.
I've taken a deep breath and am about to pull out the two culprits and re-install them. God, I hope this works! (Thanks Richard, for your very helpful advice!)
What do you all make of the various logs?
© 2018 All Rights Reserved
