Pros & Cons having FCP on a Open Directory managed Workstation
Andree Franks
on Apr 30, 2011 at 7:28:02 am
Hey guys I moved this from the OS X Forum... maybe somebody here can give me some info.
I would like to know what are the Pros and Cons having Final Cut Studio, Adobe CS5 and other 3D Applications on a Workstation that is managed over a Open Directory server?
Thank you
Gary Askham
Re: Pros & Cons having FCP on a Open Directory managed Workstation
on Apr 30, 2011 at 3:54:37 pm
We use Open Directory on all our FCP systems.
The advantages are...
- Every user has a unique login.
- Doesn't matter which system you are working on, your user settings, dock preferences, Mail settings etc follow you around.
- It sets permissions to XSAN so you can only access the files and folders you are meant to.
The disadvantages are...
- You need an administrator to take care of the server.
- Syncing is slow, complex and doesn't always work.
- All staff need to understand the system.
FCP and Avid Technical Support
Air Post Production
Shoreditch - London
Andree Franks
on Apr 30, 2011 at 4:15:21 pm
But as far for the Final Cut Pro and Co. (Adobe Cinema 4D and etc...) there should be no problems?
Michael Gossen
on Apr 30, 2011 at 4:24:18 pm
I think your only problems would be with filesystem permissions for scratch directories, distributed rendering directories, etc. ACLs on your shared filesystem should be an adequate solution though. As far as the apps, should be no issues.
Michael Gossen
Helium Digital Media
John Heagy
on May 1, 2011 at 12:29:18 am
Same here though we don't use mobile accounts all network accounts. This is not recommended for FCP but we've had no problems. The syncing is a big problem which is why we stick with network accounts.
John Heagy
Andree Franks
on May 1, 2011 at 9:22:16 pm
What you mean mobile and network accounts and what is being synced? The accounts information, Desktop settings and etc...?
Also what is ACLs
John Heagy
on May 1, 2011 at 11:49:26 pm
There are 4 types of accounts:
Local: Like the admin account the OS forces you to make when you first use a Mac.
OD Local: The same as Local but an OD server stores the passwords so one needs to be connected to one in order to login. This is the minimum if shared storage is used in order to manage permissions via ACL (Access Control List)
OD Network: The same as OD Local except the home folder is on a file server. This is what we use.
OD Network with Mobility enabled: Combination of OD network and local. The home folder is local and periodically syncs to a file server so the account exists both on the file server and any machine a user logs into. The problem is keeping all the local Mobile accounts synced. The server home and the local Mobile home seem to get out of sync easily.
If you have a Microsoft environment you can use AD to manage accounts as well.
