render limit?
Michael Garske
render limit?
on Apr 30, 2011 at 12:30:41 am
Whenever I'm rendering new items in a timeline previously rendered items become unrendered occasionally.
Is there a way of controlling the amount of allowed rendered video in a timeline to fix this? I assume it's just some kind of preference but I couldn't find any setting for that. Thanks again!
Rafael Amador
Re: render limit?
on Apr 30, 2011 at 7:24:53 am
Hi Michael,
There is no limit for rendering a sequence.
That buggy behave was very typical in some FC.5 and FC.6 versions but seems to be fixed in FC.7.
rafael
Rafael
http://www.nagavideo.com
Scott Rucci
Re: render limit?
on Apr 30, 2011 at 6:30:04 pm
Hmm. I'm working in 7 & it happens constantly unfortunately. Maybe I'll have better luck with X when it comes out. Have you ever experienced this glitch or know of any work arounds?
Scott Rucci
Rucci Productions
ruccipro.com
Ben Holmes
Re: render limit?
on May 1, 2011 at 3:33:49 pm
There was a bug in 7.0 that caused this in duplicated timelines - it was solved in 7.0.1 as far as I know, so ensure you have the latest version via software update.
Otherwise, if it happens a lot you have a bad install, or your FCP preferences are corrupted, or both. Use FCP rescue or FCP maintenance pack, and reinstall the whole suite from scratch if possible - this is one reason why an edit system should not have a lot of other software on it.
I can assure you this is NOT typical behavior for FCP suites.
Edit Out Ltd
FCP Editor/Trainer/System Consultant
EVS/VT Supervisor for live broadcast
RED camera transfer/post
Independent Director/Producer
http://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
Scott Rucci
Re: render limit?
on May 1, 2011 at 6:42:47 pm
Just FYI this post was also made by Mike, we work together, I just think he accidentally was signed on as me. : )
Scott Rucci
Rucci Productions
ruccipro.com
