Compressor Error -50
Colin Brady
on Apr 28, 2011 at 1:54:52 pm
Hi Everyone,
I've been trying to compress a sequence for some time but it keeps failing. The sequence is HDV 1080 50i. I was using H.264 compression.
The sequence is made up of Motion Movies and footage, both in XDCAM EX 1080 50i.
Everything plays fine in the timeline, I was hoping I could find out the troublesome frame that might be causing the problems. Is there any way of finding out. I checked the error log in Q Master and I can't make sense of it.
This was the status...
Job Type: Compressor
Priority: High
Time Elapsed: 0:44:14
Time Remaining: 0:00:00
Percent Complete: 100
Status: Failed - QuickTime Error: -50
Dan Monro
Re: Compressor Error -50
on Apr 28, 2011 at 4:56:20 pm
See if these help:
My guess is a corrupt file, maybe a render. I googled "QuickTime Error: -50" and came up with these. Try that, too. Didn't have time to read very far in each...
Good luck,
Dan Monro
FCP, Avid, AfterFX, Atlanta
MacBook Pro 2.53 GHz Intel Core i5 4 GB ram
Mac OS X 10.6.4
NVIDIA GeForce GT 330M
Final Cut Pro 7 Quicktime 7.6.6
- OR -
2 x 3.2 Quad Xeon; 16 GB ram
Mac OS X 10.6.4
NVIDIA Quadro FX 5600 Final Cut Pro 7.0.2 Quicktime 7.6.6
Colin Brady
on May 5, 2011 at 10:31:04 am
Thanks, but nothing there really helps. I want to get to the root of the problem by finding the corrupt file that may be causing the error.
Should the problem clip/frame not show in the failure log?
Niamath Mohamed
on Apr 14, 2012 at 9:29:25 pm
I AM getting an error quicktime error-50 when i use compressor to youtube? I did one video before with compressor and it work fine but after that I am trying it now and i keep getting this error
© 2018 All Rights Reserved
