Rendering confusion
Gautam Pandey
Rendering confusion
on Apr 28, 2011 at 12:52:21 pm
Just to understand, if i have rendered my sequence filters and all and then add a solid layer to overlay TC
It would have to render again.
My question is will it need to render only the solid layer or will it re render everything again?
Gautam Pandey
http://www.riverbankstudios.com
John Pale
Re: Rendering confusion
on Apr 28, 2011 at 1:17:38 pm
If I understand what you are trying to do...the procedure is to duplicate your sequence, select all the clips in the timeline, then nest the entire sequence. Apply the filter to the nest. If everything is already rendered, this is often a realtime effect, depending on your system specs and your working codec.
FCP renders from the top down making a single composite, so if you need to render, everything gets re-rendered.
Gautam Pandey
on Apr 28, 2011 at 2:55:02 pm
Hi John,
Thank you for responding!
I think you've got it.. basically i have 3 way CC on most of my clips, this is now rendered.
I now need to burn TC on the entire sequence.
Correct me if i'm wrong.
So if i now nest my sequence and then lay another layer over it for the TC, the sequence would need to be re rendered only the layer with TC will.
Gautam Pandey
John Pale
on Apr 28, 2011 at 6:06:52 pm
Don't add another layer. Apply the filter to the nest.
Gautam Pandey
on Apr 28, 2011 at 7:36:24 pm
Super! Thanks a ton John.. will do this first thing tomorrow :)
Gautam Pandey
